Introdução
Be careful when removing the haptic motor. There are two wires that can be easily ripped out. For this replacement, you will need a soldering iron.
O que você precisa
Obtain the black plastic spudger tool from the iFixit toolkit. Position the device as shown in the picture. Insert the flat end of the spudger directly in the space above the power button between the back cover and front screen.
After removing the back cover, you will be able to gain access to the speaker component.
Conclusão
