Ir para o conteúdo principal
Vivotek FD8169 Motherboard Replacement
O que você precisa
  1. Vivotek FD8169 Motherboard Replacement, Dome Cover: passo 1, imagem 1 %32
    • Loosen the outside screw.
  2. Vivotek FD8169 Motherboard Replacement: passo 2, imagem 1 %32
    • Press down on the side button, and lift up the top dome.
  3. Vivotek FD8169 Motherboard Replacement, Camera Module: passo 3, imagem 1 %32
    • Remove three screws that connect the camera base to the motherboard using a Phillips #1 screwdriver.
  4. Vivotek FD8169 Motherboard Replacement: passo 4, imagem 1 %32
    • Lift off the camera base from the motherboard.
  5. Vivotek FD8169 Motherboard Replacement: passo 5, imagem 1 %32
    • Unscrew the cord from the motherboard.
    • Unplug the remaining connection.
  6. Vivotek FD8169 Motherboard Replacement: passo 6, imagem 1 %32
    • Unscrew the camera from the camera base with a hex screwdriver on both sides.
  7. Vivotek FD8169 Motherboard Replacement: passo 7, imagem 1 %32
    • Pull the camera out from the camera base.
  8. Vivotek FD8169 Motherboard Replacement, Motherboard: passo 8, imagem 1 %32
    • Once the camera module is removed, unscrew the two remaining screws which attach the motherboard to the backplate.
  9. Vivotek FD8169 Motherboard Replacement: passo 9, imagem 1 %32
    • Once the screws are gone, lift the faulty motherboard and replace with a new one.
Conclusão
Artem Dudko
Membro desde: 10/18/21
135 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-6, Simcock Fall 2021 Membro de UMass Dartmouth, Team 1-6, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G6
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 19
Duração total: 245
