Ir para o conteúdo principal
Vivitar XO 7 Motherboard Replacement
O que você precisa
  1. Vivitar XO 7 Motherboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the two 3mm Phillips #00 screws on the bottom of the tablet.
  2. Vivitar XO 7 Motherboard Replacement: passo 2, imagem 1 %32
    • With the plastic opening tools, pry open the back cover.
  3. Vivitar XO 7 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the back cover from the tablet.
  4. Vivitar XO 7 Motherboard Replacement, Battery: passo 4, imagem 1 %32 Vivitar XO 7 Motherboard Replacement, Battery: passo 4, imagem 2 %32
    • Peel off the black pieces of tape from the internal components.
  5. Vivitar XO 7 Motherboard Replacement: passo 5, imagem 1 %32 Vivitar XO 7 Motherboard Replacement: passo 5, imagem 2 %32
    • Carefully remove the battery from the tablet.
  6. Vivitar XO 7 Motherboard Replacement: passo 6, imagem 1 %32 Vivitar XO 7 Motherboard Replacement: passo 6, imagem 2 %32
    • With the tweezers, firmly grab the wire at the base and pull to disconnect the battery from the motherboard.
  7. Vivitar XO 7 Motherboard Replacement, Speaker: passo 7, imagem 1 %32
    • Carefully remove the speaker from the metal plate with your hands.
  8. Vivitar XO 7 Motherboard Replacement: passo 8, imagem 1 %32 Vivitar XO 7 Motherboard Replacement: passo 8, imagem 2 %32
    • With tweezers, firmly grab the wire at the base and pull to disconnect the speaker from the motherboard.
  9. Vivitar XO 7 Motherboard Replacement, Camera: passo 9, imagem 1 %32
    • Peel off black tape that is holding the camera in place.
  10. Vivitar XO 7 Motherboard Replacement: passo 10, imagem 1 %32
    • Carefully disconnect the ribbon cables from the motherboard.
  11. Vivitar XO 7 Motherboard Replacement: passo 11, imagem 1 %32 Vivitar XO 7 Motherboard Replacement: passo 11, imagem 2 %32
    • Using the tweezers, firmly grab wires and pull to disconnect them from the motherboard.
  12. Vivitar XO 7 Motherboard Replacement, Motherboard: passo 12, imagem 1 %32
    • Disconnect the large golden ribbon cable that is connected to the digitizer. Firmly grab the cable close to the connection and pull to disconnect.
  13. Vivitar XO 7 Motherboard Replacement: passo 13, imagem 1 %32
    • Remove four 4mm PH00 silver screws from the motherboard.
  14. Vivitar XO 7 Motherboard Replacement: passo 14, imagem 1 %32
    • Remove two 2mm PH00 black screws from the motherboard.
  15. Vivitar XO 7 Motherboard Replacement: passo 15, imagem 1 %32
    • Carefully remove the silver cover from the motherboard.
  16. Vivitar XO 7 Motherboard Replacement: passo 16, imagem 1 %32 Vivitar XO 7 Motherboard Replacement: passo 16, imagem 2 %32
    • Gently pick up and turn over the motherboard. While turned over, disconnect the last ribbon cable that connects to screen.
Conclusão
James Lunn
Membro desde: 01/20/15
116 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 11-1, Blackwell Winter 2015 Membro de USF Tampa, Team 11-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S11G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 927
