Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
Remove the sticker on the top of the camera. This sticker covers a screw.
Remove five screws on the sides of the camera, including the screw under the sticker.
Separate the front piece of the camera from the back to reveal the motherboard.
Remove the plastic silver strip from the front case of the camera.
Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
Remove the black plastic cover to reveal the newly exposed screen.
Carefully remove the gold film from the screen with a plastic opening tool.
Gently pull the screen off the camera.
Uma outra pessoa concluiu este guia.
2 comentários
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
How much would a screen replacement for a Vivitar Vivicam s124
