Ir para o conteúdo principal
Introdução
Replace your screen if it is cracked or otherwise damaged.
Peças
Nenhum componente especificado.
  1. Remove the 3 mm screws at the sides of the camera using a Phillips #00 screwdriver. Remove the 3 mm screws at the sides of the camera using a Phillips #00 screwdriver.
    • Remove the 3 mm screws at the sides of the camera using a Phillips #00 screwdriver.
  2. Remove sticker on top of camera as it covers a screw.
    • Remove sticker on top of camera as it covers a screw.
    • There should be 5 screws to remove in total on the sides of the camera.
  3. Separate the front piece of the camera from the back, revealing the motherboard. Separate the front piece of the camera from the back, revealing the motherboard.
    • Separate the front piece of the camera from the back, revealing the motherboard.
  4. Remove plastic silver strip from the front case of the camera.
    • Remove plastic silver strip from the front case of the camera.
  5. Remove the three 2 mm screws holding in the gray plastic piece using a Phillips #00 screwdriver.
    • Remove the three 2 mm screws holding in the gray plastic piece using a Phillips #00 screwdriver.
  6. Remove the black plastic cover to reveal the newly exposed screen.
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Carefully remove gold film from the screen with a plastic opening tool. Gently pull the screen off the camera.
    • Carefully remove gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Nicole Knoebel
Membro desde: 11/03/2015
258 Reputação
2 Guias de autoria
Equipe
Marist, Team 15-13, Laflen Spring 2015 Membro de Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
4 Membros
3 Guias de autoria
2 comentários
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Responder
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 499
