Ir para o conteúdo principal
Vivitar Vivicam T027 Screen Replacement
O que você precisa
  1. Vivitar Vivicam T027 Screen Replacement, Screen: passo 1, imagem 1 %32 Vivitar Vivicam T027 Screen Replacement, Screen: passo 1, imagem 2 %32
    • Remove the 3 mm screws on the sides of the camera, using a Phillips #00 screwdriver.
  2. Vivitar Vivicam T027 Screen Replacement: passo 2, imagem 1 %32
    • Remove the sticker on the top of the camera. This sticker covers a screw.
    • Remove five screws on the sides of the camera, including the screw under the sticker.
  3. Vivitar Vivicam T027 Screen Replacement: passo 3, imagem 1 %32 Vivitar Vivicam T027 Screen Replacement: passo 3, imagem 2 %32
    • Separate the front piece of the camera from the back to reveal the motherboard.
  4. Vivitar Vivicam T027 Screen Replacement: passo 4, imagem 1 %32
    • Remove the plastic silver strip from the front case of the camera.
  5. Vivitar Vivicam T027 Screen Replacement: passo 5, imagem 1 %32
    • Remove the three 2 mm screws holding in the gray plastic cover, using a Phillips #00 screwdriver.
  6. Vivitar Vivicam T027 Screen Replacement: passo 6, imagem 1 %32
    • Remove the black plastic cover to reveal the newly exposed screen.
  7. Vivitar Vivicam T027 Screen Replacement: passo 7, imagem 1 %32 Vivitar Vivicam T027 Screen Replacement: passo 7, imagem 2 %32
    • Carefully remove the gold film from the screen with a plastic opening tool.
    • Gently pull the screen off the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Nicole Knoebel
Membro desde: 03/11/15
258 Reputação
Autoria de 2 guias
Equipe
Marist, Team 15-13, Laflen Spring 2015 Membro de Marist, Team 15-13, Laflen Spring 2015
MARS-LAFLEN-S15S15G13
Membros da 4
Autoria de 3 guias
2 comentários
Any heat required for this? How would I tap into the a/v feed from a digital camera to extend the screen? Data output to the sd card or usb?
Scott Haddox - Responder
How much would a screen replacement for a Vivitar Vivicam s124
SavageDoll Face - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 845
