Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Place waterproof case on flat surface, with the lens cover facing up.
Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
Uma outra pessoa concluiu este guia.
Um comentário
Hello, do you know where I can acquire a replacement water proof case for my Vivitar DVR 787 HD action camcorder?
