Ir para o conteúdo principal
Vivitar DVR 781HD Waterproof Case Lens Cover Replacement
O que você precisa
  1. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement, Waterproof Case Lens Cover: passo 1, imagem 1 %32
    • Place waterproof case on flat surface, with the lens cover facing up.
  2. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 2, imagem 1 %32 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 2, imagem 2 %32
    • Remove the six 4.5mm Phillips #00 screws from the black lens cover trim.
    Saya minat dengan cas nya gmna cara pesannya gan
    Longor87 Qwertyuiop - Responder
  3. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 3, imagem 1 %32 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 3, imagem 2 %32
    • While holding the black lens cover trim tight to the case, flip the case over so that the lens cover is rested on your work surface.
  4. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 4, imagem 1 %32 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 4, imagem 2 %32
    • Apply pressure to the lens cover with your thumb, and use your other fingers to pull up on the case, separating the lens and lens trim from the case.
  5. Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 5, imagem 1 %32 Vivitar DVR 781HD Waterproof Case Lens Cover Replacement: passo 5, imagem 2 %32
    • There is a small plastic key on the black bezel that aligns it to the case. Be sure to line this up during reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Jordan Baum
Membro desde: 02/13/16
355 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 54-6, Wilson Spring 2016 Membro de IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
Membros da 3
Autoria de 10 guias
Um comentário
Hello, do you know where I can acquire a replacement water proof case for my Vivitar DVR 787 HD action camcorder?
Andrew Hinsley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 1,249
