Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide provides the instructions needed to remove the motherboard from the 781HD DVR camcorder.
O que você precisa
Begin with the camcorder lens up on a clear working surface.
Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
Using a P1 screwdriver, remove the 4mm screws holding the motherboard into the case.
3 comentários
It says no parts required, but it is instructions to replace the motherboard.
There is nothing about getting another motherboard, and how much.
How do you get a motherboard?
Where do we get one?
