Ir para o conteúdo principal
Vivitar DVR 781HD Front Case Replacement
O que você precisa
  1. Vivitar DVR 781HD Front Case Replacement, Front Case: passo 1, imagem 1 %32 Vivitar DVR 781HD Front Case Replacement, Front Case: passo 1, imagem 2 %32 Vivitar DVR 781HD Front Case Replacement, Front Case: passo 1, imagem 3 %32
    • Begin with the camcorder lens up on a clear working surface.
    • Remove the two 4mm Phillips #1 screws holding the switch plate in place. Rotate the device 180 degrees and repeat for the screws on the opposite side.
  2. Vivitar DVR 781HD Front Case Replacement: passo 2, imagem 1 %32
    • Slide the plastic opening tool into the seam between the front and back sections of the case and apply a small amount of force to pop the case open.
  3. Vivitar DVR 781HD Front Case Replacement: passo 3, imagem 1 %32 Vivitar DVR 781HD Front Case Replacement: passo 3, imagem 2 %32 Vivitar DVR 781HD Front Case Replacement: passo 3, imagem 3 %32
    • Move the plastic opening tool around the seam and apply force at each step to separate the front plate from the back plate and motherboard.
    • The battery is held to the front half of the case with double-sided tape. Peel it up with a finger, being careful not to damage the battery.
Conclusão
Jordan Baum
Membro desde: 02/13/16
355 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 54-6, Wilson Spring 2016 Membro de IUPUI, Team 54-6, Wilson Spring 2016
IUPUI-WILSON-S16S54G6
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 308
