Ir para o conteúdo principal
Visual Land Prestige Pro 7D Back Panel Replacement
O que você precisa
  1. Visual Land Prestige Pro 7D Back Panel Replacement, Back Panel: passo 1, imagem 1 %32
    • Unscrew the two 4.0mm Phillips head screws found near the ports at the bottom of the device using a PH #00 screwdriver.
  2. Visual Land Prestige Pro 7D Back Panel Replacement: passo 2, imagem 1 %32
    • Be careful when taking the back panel off. The speaker is connected to both the front and back panels, and may get pulled out if you are not gentle when lifting the back panel away.
    • Slide the plastic prying tool in between the front and back panel and pry them apart on all 4 sides.
    • It may be easiest to start on one of the sides, and work your way around the device. The bottom, with the ports, is the most difficult side and can be saved for last.
    • There are small latches that make this difficult. Moderate force may be required to separate the two panels.
Conclusão
6 outras pessoas executaram este guia.
Max Hudson
Membro desde: 10/14/14
422 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 10-41, Amido Fall 2014 Membro de Cal Poly, Team 10-41, Amido Fall 2014
CPSU-AMIDO-F14S10G41
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,580
