Ir para o conteúdo principal
Visual Land Prestige 7L Back Panel Replacement
O que você precisa
  1. Visual Land Prestige 7L Back Panel Replacement, Back Panel: passo 1, imagem 1 %32 Visual Land Prestige 7L Back Panel Replacement, Back Panel: passo 1, imagem 2 %32
    • Remove the two 8mm Phillips Head screws located at the bottom of your device.
  2. Visual Land Prestige 7L Back Panel Replacement: passo 2, imagem 1 %32 Visual Land Prestige 7L Back Panel Replacement: passo 2, imagem 2 %32 Visual Land Prestige 7L Back Panel Replacement: passo 2, imagem 3 %32
    • Insert the spudger between the two pieces of the case around the media ports and pry them apart.
    • We found the best way to get the spudger inside the case was to insert in into the SD card slot. Be sure to only insert the spudger a shallow amount and be careful not to damage any of the inside of the device.
    • Finish unsnapping each plastic piece holding the device together along the bottom.
  3. Visual Land Prestige 7L Back Panel Replacement: passo 3, imagem 1 %32 Visual Land Prestige 7L Back Panel Replacement: passo 3, imagem 2 %32 Visual Land Prestige 7L Back Panel Replacement: passo 3, imagem 3 %32
    • Move the spudger down the rest of the case, separating each side, and finally the top.
    • Pull the back off and place it to the side.
    • Without a back panel for protection, be sure place your device on the table screen-side down to avoid damaging the internal circuitry.
Conclusão
Uma outra pessoa concluiu este guia.
Robert
Membro desde: 01/28/15
141 Reputação
Autoria de 1 guia
Equipe
Penn State, Team 2-25, Kaschak Winter 2015 Membro de Penn State, Team 2-25, Kaschak Winter 2015
PSU-KASCHAK-W15S2G25
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 542
