Ir para o conteúdo principal
Visual Land Prestige 7G Speaker Replacement
O que você precisa
  1. Visual Land Prestige 7G Speaker Replacement, Backplate: passo 1, imagem 1 %32 Visual Land Prestige 7G Speaker Replacement, Backplate: passo 1, imagem 2 %32
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Speaker Replacement: passo 2, imagem 1 %32
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Speaker Replacement: passo 3, imagem 1 %32 Visual Land Prestige 7G Speaker Replacement: passo 3, imagem 2 %32
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Speaker Replacement, Speaker: passo 4, imagem 1 %32 Visual Land Prestige 7G Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Take the soldering gun and place it on the black and red wires to melt the soldered conncetions.
    • Remove the speaker.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 33
