Ir para o conteúdo principal
Visual Land Prestige 7G Motherboard Replacement
O que você precisa
  1. Visual Land Prestige 7G Motherboard Replacement, Backplate: passo 1, imagem 1 %32 Visual Land Prestige 7G Motherboard Replacement, Backplate: passo 1, imagem 2 %32
    • Lay your device face-down.
    • Use a Phillips #000 screwdriver to remove the two 4 mm screws next to the AUX port and microphone.
  2. Visual Land Prestige 7G Motherboard Replacement: passo 2, imagem 1 %32
    • Pry open the back-plate using a Jimmy.
    • Do this by inserting the tool into the fine thin line between the back-plate and screen at each corner of the device.
  3. Visual Land Prestige 7G Motherboard Replacement: passo 3, imagem 1 %32 Visual Land Prestige 7G Motherboard Replacement: passo 3, imagem 2 %32
    • Lift off the backplate using your hand.
    • If the backplate is stuck, repeat the previous step to ensure all the edges are free.
  4. Visual Land Prestige 7G Motherboard Replacement, Motherboard: passo 4, imagem 1 %32 Visual Land Prestige 7G Motherboard Replacement, Motherboard: passo 4, imagem 2 %32 Visual Land Prestige 7G Motherboard Replacement, Motherboard: passo 4, imagem 3 %32
    • Lay the device on its back.
    • Flip up the black locking flap then remove the ribbon cables.
  5. Visual Land Prestige 7G Motherboard Replacement: passo 5, imagem 1 %32 Visual Land Prestige 7G Motherboard Replacement: passo 5, imagem 2 %32 Visual Land Prestige 7G Motherboard Replacement: passo 5, imagem 3 %32
    • Connected to the motherboard there will be a red, black, and grey wire.
    • Use a soldering iron to melt the soldered contact points.
    • Disconnect the wires.
    • Lift the motherboard up and out of the chassis.
    • The high temperatures of a soldering gun and melted solder may create the potential for burns. Inhaling the fumes in an enclosed environment may also lead to irritation and desensitization of the eyes and respiratory tract.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 43
