Ir para o conteúdo principal
Visual Land Prestige 10 Motherboard Replacement
O que você precisa
  1. Visual Land Prestige 10 Motherboard Replacement, Back Case: passo 1, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement, Back Case: passo 1, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement, Back Case: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Motherboard Replacement: passo 2, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 2, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement: passo 2, imagem 3 %32
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Motherboard Replacement: passo 3, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 3, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement: passo 3, imagem 3 %32
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Motherboard Replacement: passo 4, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 4, imagem 2 %32
    Comprar
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Motherboard Replacement, Battery: passo 5, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement, Battery: passo 5, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement, Battery: passo 5, imagem 3 %32
    • Remove yellow tape from surrounding components.
  6. Visual Land Prestige 10 Motherboard Replacement: passo 6, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 6, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement: passo 6, imagem 3 %32
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Visual Land Prestige 10 Motherboard Replacement: passo 7, imagem 1 %32
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
  8. Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: passo 8, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: passo 8, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement, Front Facing Camera: passo 8, imagem 3 %32
    • Locate the Camera Housing. Gently grip and lift the small black tab until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head or as close as possible.
    • Gently grip and pull up the front camera, covered by protective adhesive foam.
    • Set aside the Camera housing.
  9. Visual Land Prestige 10 Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement, Motherboard: passo 9, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement, Motherboard: passo 9, imagem 3 %32
    Comprar
    • Locate the LCD Connector.
    • Using tweezers, grip the small black tab connected to the white plastic.
    • Gently lift the tab towards you until it clicks.
    • Remove the connector by pulling straight out, gripping the black connector head.
  10. Visual Land Prestige 10 Motherboard Replacement: passo 10, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 10, imagem 2 %32 Visual Land Prestige 10 Motherboard Replacement: passo 10, imagem 3 %32
    • Locate the Touchscreen connector and grip the forward-most black tab with the tweezers.
    • Lift the tab towards you until you feel an audible click.
    • Gently remove the connector by pulling straight out, gripping the black connector head.
  11. Visual Land Prestige 10 Motherboard Replacement: passo 11, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 11, imagem 2 %32
    • Gently lift up the WiFi antenna and set aside.
  12. Visual Land Prestige 10 Motherboard Replacement: passo 12, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 12, imagem 2 %32
    • Locate and remove the screws holding the volume and hold button controller. Set screws aside on magnetic mat and label them.
    • Gently lift up on the controller and leave it hanging loose.
  13. Visual Land Prestige 10 Motherboard Replacement: passo 13, imagem 1 %32 Visual Land Prestige 10 Motherboard Replacement: passo 13, imagem 2 %32
    • Remove screws located on motherboard.
    • Place on magnetic mat and label them
    • Gently remove the Motherboard and any wires connected to it and set it aside on a static free surface.
Conclusão
6 outras pessoas executaram este guia.
Um comentário
I just received my tablet. and it will not allow me to set up a password. It keeps asking for previous password. I have done a hard reset but have not been able to set up my tablet.
John Jefferson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 1,613
