Ir para o conteúdo principal
Visual Land Prestige 10 Battery Replacement
O que você precisa
  1. Visual Land Prestige 10 Battery Replacement, Back Case: passo 1, imagem 1 %32 Visual Land Prestige 10 Battery Replacement, Back Case: passo 1, imagem 2 %32 Visual Land Prestige 10 Battery Replacement, Back Case: passo 1, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Remove the 3mm screws from bottom of tablet with the precision screwdriver and place on magnetic mat. label where they came from.
    • All screws throughout this guide are the same 3mm size.
  2. Visual Land Prestige 10 Battery Replacement: passo 2, imagem 1 %32 Visual Land Prestige 10 Battery Replacement: passo 2, imagem 2 %32 Visual Land Prestige 10 Battery Replacement: passo 2, imagem 3 %32
    • Using the spudger, create a small opening to be used to open the back case.
    • While holding the case open, insert the plastic opening tool to get a larger opening.
    • Once you have a slight opening, insert the spudger and work around the edges, separating the back plate from the front.
  3. Visual Land Prestige 10 Battery Replacement: passo 3, imagem 1 %32 Visual Land Prestige 10 Battery Replacement: passo 3, imagem 2 %32 Visual Land Prestige 10 Battery Replacement: passo 3, imagem 3 %32
    • now that the case is open, carefully remove the speakers and set aside.
  4. Visual Land Prestige 10 Battery Replacement: passo 4, imagem 1 %32 Visual Land Prestige 10 Battery Replacement: passo 4, imagem 2 %32
    Comprar
    • Gently remove the speakers from the back case with tweezers and set the case aside.
  5. Visual Land Prestige 10 Battery Replacement, Battery: passo 5, imagem 1 %32 Visual Land Prestige 10 Battery Replacement, Battery: passo 5, imagem 2 %32 Visual Land Prestige 10 Battery Replacement, Battery: passo 5, imagem 3 %32
    • Remove yellow tape from surrounding components.
  6. Visual Land Prestige 10 Battery Replacement: passo 6, imagem 1 %32 Visual Land Prestige 10 Battery Replacement: passo 6, imagem 2 %32 Visual Land Prestige 10 Battery Replacement: passo 6, imagem 3 %32
    • insert the spudger and gently work around and underneath the battery.
    • With the battery separated from the LCD Display, set it aside.
    • The battery is held down by very strong adhesive.
  7. Visual Land Prestige 10 Battery Replacement: passo 7, imagem 1 %32
    • Desolder and remove the 2 wires from the motherboard.
    • Use caution when desoldering to avoid damage to yourself or to the components.
Conclusão
8 outras pessoas executaram este guia.
7 comentários
Wat if the charge port how do u replace it Visaul land 10.1
jessiepettway - Responder
Thank you for posting. Great illustrations. Got mine apart so easy.
Lori Pepper - Responder
where can I get a replacement battery for Visual Land Prestige 10D tablet?
John Conger - Responder
Where can I get a replacement battery for Visual Land Prestige 10.1 tablet???
Thank you.
Belinda Rivera
brp52@hotmail.com
Belinda Lorenzana - Responder
where can I get a replacement battery for visionland prestige 10 3.7v
Fred Maxwell - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 8,202
