Ir para o conteúdo principal
Vintage Mini Vornado Fan Blade Replacement
O que você precisa
  1. Vintage Mini Vornado Fan Blade Replacement, Fan Blade: passo 1, imagem 1 %32 Vintage Mini Vornado Fan Blade Replacement, Fan Blade: passo 1, imagem 2 %32
    • Prop the cap out of each hole with a pry tool to remove the blade cap.
    • To remove the blade cap, you will need to pop out three different areas of the cap from the fan. There are three small holes around the perimeter of the fan that the cap is secured into.
    Pergunte ao FixBot
    Comentar
  2. Vintage Mini Vornado Fan Blade Replacement: passo 2, imagem 1 %32
    • Face the front of the fan and pull the blade directly towards you to loosen it.
    • Pull the blade out of the rod.
    • Take note of the blade's orientation.
    Pergunte ao FixBot
    Comentar
  3. Vintage Mini Vornado Fan Blade Replacement: passo 3, imagem 1 %32
    • If you have purchased a new blade, make sure the orientation matches the one you just removed.
    Pergunte ao FixBot
    Comentar
  4. Vintage Mini Vornado Fan Blade Replacement: passo 4, imagem 1 %32
    • Use a cloth to dust the blade or other interior areas of the fan.
    Pergunte ao FixBot
    Comentar
  5. Vintage Mini Vornado Fan Blade Replacement: passo 5, imagem 1 %32
    • Place the blade back inside of the fan.
    • The blade should fit snug when the rod is fully inserted.
    Pergunte ao FixBot
    Comentar
  6. Vintage Mini Vornado Fan Blade Replacement: passo 6, imagem 1 %32 Vintage Mini Vornado Fan Blade Replacement: passo 6, imagem 2 %32
    • Place the blade cap on and secure it into the three holes.
    • Use a pry tool with a cloth to help apply pressure and push the cap into place.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
Claire Minahan
Membro desde: 02/01/23
169 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 2-3, Johann Winter 2023 Membro de Cal Poly, Team 2-3, Johann Winter 2023
CPSU-JOHANN-W23S2G3
2 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 73
Ao todo: 1,141
