Introdução
Learn how to properly replace a zipper slider.
O que você precisa
Instruções em vídeo
Quase terminado!
Conclusão
6 comentários
Any suggestions for where to buy new zipper top stops?
Emily Mason-Osann - Responder
I have the same question. Where can I get the pieces I need? My zipper slider fell off the bottom of my jacket, too, and so I do not know exactly which one to replace it with (even if I knew where to buy it!)
Melodie Stenger - Responder
Same problem here. The zipper slider fell off the bottom of the jacket. Is it even possible to get replacement parts for a zipper?
tquaif - Responder
I found everything I needed on sailrite.com. Good luck with your repair.
Karen Libby -
Now I need to find a top stop and a replacement zipper, and that snipper tool.
nick strauss - Responder
To determine what type and size of slider you might need, please check out this guide below. Video: Introduction to Zipper Types and Slider Identification
Once you know which type and size you need contact Patagonia Customer Service ( 1-800-638-6464) for a new Slider and Zipper Stop. Please have your type and size available to provide to the CS Agent.
Tools for the job were listed above in the "Tools" section, if you place your cursor over the link a little window will pop up. If you click on it it will take you to a vendor to purchase any tool that needed.
Good Luck.
Marty Chapman - Responder
