Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Insert a prying tool into the stylus casing, right above the red casing.
Push the casing down with the prying tool, releasing it so it can be removed.
Connect the new casing, applying it at an angle up and towards the back of the head of the tone arm.
Move the new casing up and into place where it will lock.
Ferramenta utilizada nesse passo:Microfiber Cleaning Cloths$3.99-
Using a dry microfiber cloth, wipe off a vinyl record.
Listen to how the turntable sounds when turned on. Listen for warbles, crackles, pops, and other non-desirable noise.
2 comentários
My warranty is out (bought mine in 2017) and Victrola has been no help. They wont replace any parts, and so suggested I do an online search for 3rd party parts. But, I don’t even know what to look for. The arm on my unit is broken, what part do I need or what do I search for? I have the Model VTA-200B (music center with Bluetooth) Serial #: D170604182ITC. I tried to attach a pic, but can’t here.
Hi Monica,
After doing some research, it seems like you can only really replace the needle. If the arm is broken, you may need to find that individual with the plastic motor for sale online. But I'm not having luck finding any Victrola arms for sale either.
