Ir para o conteúdo principal
Vertical Blind Slat Replacement
  1. Vertical Blind Slat Replacement, Slat: passo 1, imagem 1 %32 Vertical Blind Slat Replacement, Slat: passo 1, imagem 2 %32
    • Remove the old slat by lifting it upwards.
  2. Vertical Blind Slat Replacement: passo 2, imagem 1 %32 Vertical Blind Slat Replacement: passo 2, imagem 2 %32
    • Once lifted, gently pull the slat toward you to remove it completely from the clip.
  3. Vertical Blind Slat Replacement: passo 3, imagem 1 %32
    • Adjust and ensure the curve of the new slat is facing the same direction as the other old slats.
  4. Vertical Blind Slat Replacement: passo 4, imagem 1 %32
    • Slide the new slat upwards into the first clip.
  5. Vertical Blind Slat Replacement: passo 5, imagem 1 %32
    • Continue sliding the slat upwards until it clicks into place in the second clip.
  6. Vertical Blind Slat Replacement: passo 6, imagem 1 %32
    • Once finished, gently pull the slat toward you to ensure it is securely attached.
Linha de Chegada
KA YEE LUI
Membro desde: 07/03/24
133 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 116
