Ir para o conteúdo principal
Vertical Blind Repairing
O que você precisa
Documento em destaque
  1. Vertical Blind Repairing, View the problem: passo 1, imagem 1 %32
    • 1. Identify the problem with the blind.
  2. Vertical Blind Repairing, Removal: passo 2, imagem 1 %32
    • 2. Use your hand to carefully remove the blind.
  3. Vertical Blind Repairing, Examine: passo 3, imagem 1 %32
    • 3. Look at the part you took off and see if the problem is with the top part of the blind.
  4. Vertical Blind Repairing, Material Ready: passo 4, imagem 1 %32
    • 4. Make sure to have some glue or tape to fix the hole on top of the blind so you can be able to reassemble it.
  5. Vertical Blind Repairing, Patience: passo 5, imagem 1 %32
    • 5. Wait a few minutes for the glue to dry.
  6. Vertical Blind Repairing, Repair: passo 6, imagem 1 %32
    • 6. Reassemble the blind in the same place.
  7. Vertical Blind Repairing, Finish: passo 7, imagem 1 %32
    • 7. Test the blinds by moving them side to side.
Conclusão
Documentos anexados
Group 3
Membro desde: 10/31/18
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 16
Últimos 30 dias: 49
Ao todo: 753
