O que você precisa
Passo 1 Prepare your phone
Cuidado: as etapas de 1 a 4 são provenientes de um guia marcado como em andamento.
Shut down your phone.
Set the phone down on a soft surface with space to store removed parts safely.
Unclip and remove the rear cover,
Remove any SIM/MicroSD cards.
Unscrew 12 black screws. A magnet is helpful for storing them. Try a fridge magnet face down.
Use a pick or your thumbnail around the display bezel to separate the frame from the phone.
Set aside the frame being careful not to lose the volume and power buttons.
Gently pry the battery plug up as shown.
Bend the cable up so the plug can't touch the board.
Unpick the white tabs from the top of the battery and pull gently and slowly as shown. Be careful not to snag the tapes. If both tapes come out cleanly the battery will be free. Hold the battery down with your other hand.
Remove the motherboard by carefully prying up the LCD connector, removing one black screw, and releasing the clamp that holds the flexible cable for the buttons
Be careful when you lift the board out so as not to disturb the cameras which you can leave attached to the board.
Transfer the earpiece speaker and the sensor block to the new screen before reinstalling the motherboard
Be careful to tuck the cameras gently into place.
Gently peel up the cable that joins the motherboard to the daughterboard and transfer it along with the coaxial cable.
Transfer the daughterboard to the new screen.
Uma outra pessoa concluiu este guia.
