Ir para o conteúdo principal
Verizon Wireless CDM 7075 Screen Replacement
O que você precisa
  1. Verizon Wireless CDM 7075 Screen Replacement, Battery: passo 1, imagem 1 %32 Verizon Wireless CDM 7075 Screen Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
  2. Verizon Wireless CDM 7075 Screen Replacement: passo 2, imagem 1 %32
    • Carefully remove the battery from the phone by prying the battery from the top.
  3. Verizon Wireless CDM 7075 Screen Replacement, Screen: passo 3, imagem 1 %32
    • Remove the rubber plugs from the screw holes around the screen with the opening tool.
  4. Verizon Wireless CDM 7075 Screen Replacement: passo 4, imagem 1 %32
    • Remove the four screws from around the phone's screen with a Phillips screwdriver.
  5. Verizon Wireless CDM 7075 Screen Replacement: passo 5, imagem 1 %32
    • Pry the top cover off the phone with a plastic opening tool.
  6. Verizon Wireless CDM 7075 Screen Replacement: passo 6, imagem 1 %32
    • Remove the screen assembly from the phone.
  7. Verizon Wireless CDM 7075 Screen Replacement: passo 7, imagem 1 %32
    • Pry the circuit board off of the screen with the opening tool.
Conclusão
Corey Ryman
Membro desde: 10/14/11
255 Reputação
Autoria de 4 guias
Equipe
James Madison, Team 2-4, Allen Fall 2011 Membro de James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 1,094
