Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Please ensure you have followed the prerequisite guide of removing the battery before proceeding with this guide.
Peças
Nenhum componente especificado.
  1. To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off. To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
    • To remove the back panel, first press and hold the gray button on the back. While doing that also press and slide the panel down and off.
  2. Carefully remove the battery from the phone by prying it from the top.
    • Carefully remove the battery from the phone by prying it from the top.
  3. With the opening tool, remove the rubber plugs from the screw holes around the screen.
    • With the opening tool, remove the rubber plugs from the screw holes around the screen.
  4. Kits para Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. With a Philips screwdriver, remove the four screws from around the phone's screen.
    • With a Philips screwdriver, remove the four screws from around the phone's screen.
  6. Pry the top cover off the phone with a plastic opening tool.
    • Pry the top cover off the phone with a plastic opening tool.
  7. Remove the screen assembly from the phone.
    • Remove the screen assembly from the phone.
  8. With the opening tool, pry the circuit board off of the screen.
    • With the opening tool, pry the circuit board off of the screen.
Conclusão
Corey Ryman
Membro desde: 14-10-2011
255 Reputação
4 Guias de autoria
equipe
James Madison, Team 2-4, Allen Fall 2011 Membro de James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Membros
8 Guias de autoria
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 948
