Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
Carefully remove the battery from the phone by prying the battery from the top.
You will then remove the screws from the back of the phone.
Next you will pry apart the two halves of the phone.
Then use the plastic opening tool to remove the motherboard from the front half of the phone.
Next you will peel off the keypad after the motherboard is removed.
Lastly insert the new keypad.
Uma outra pessoa concluiu este guia.
