Ir para o conteúdo principal
Verizon Wireless CDM 7075 Keypad Replacement
O que você precisa
  1. Verizon Wireless CDM 7075 Keypad Replacement, Battery: passo 1, imagem 1 %32 Verizon Wireless CDM 7075 Keypad Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back panel by first pressing and holding the gray button on the back. While doing that also press and slide the panel down and off.
    Pergunte ao FixBot
    Comentar
  2. Verizon Wireless CDM 7075 Keypad Replacement: passo 2, imagem 1 %32
    • Carefully remove the battery from the phone by prying the battery from the top.
    Pergunte ao FixBot
    Comentar
  3. Verizon Wireless CDM 7075 Keypad Replacement, Keypad: passo 3, imagem 1 %32
    • Pry off the top cover on the back of the phone.
    Pergunte ao FixBot
    Comentar
  4. Verizon Wireless CDM 7075 Keypad Replacement: passo 4, imagem 1 %32
    • You will then remove the screws from the back of the phone.
    Pergunte ao FixBot
    Comentar
  5. Verizon Wireless CDM 7075 Keypad Replacement: passo 5, imagem 1 %32
    • Next you will pry apart the two halves of the phone.
    • Make sure you do not to damage the ribbon cable connecting both halves
    Pergunte ao FixBot
    Comentar
  6. Verizon Wireless CDM 7075 Keypad Replacement: passo 6, imagem 1 %32
    • Then use the plastic opening tool to remove the motherboard from the front half of the phone.
    Pergunte ao FixBot
    Comentar
  7. Verizon Wireless CDM 7075 Keypad Replacement: passo 7, imagem 1 %32
    • Next you will peel off the keypad after the motherboard is removed.
    • Be sure you do not to tear the brown connector tape.
    • Lastly insert the new keypad.
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Corey Ryman
Membro desde: 10/14/11
255 Reputação
Autoria de 4 guias
Equipe
James Madison, Team 2-4, Allen Fall 2011 Membro de James Madison, Team 2-4, Allen Fall 2011
JMU-ALLEN-F11S2G4
3 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 60
Ao todo: 1,458
