Ir para o conteúdo principal
Verizon Ellipsis Jetpack MHS800L Screen Replacement
O que você precisa
  1. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, imagem 2 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Plastic Case: passo 1, imagem 3 %32
    • Remove the SIM card, that is located on top of the Jetpack.
  2. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, imagem 2 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    Phillips #00 Screwdriver
    $5.49
    • With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
    • Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
    • You may need to peel back a piece of double sided tape covering the screw hole.
  3. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 3, imagem 1 %32
    • Remove three 1.25 mm screws.
  4. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 4, imagem 1 %32
    iFixit Opening Picks (Set of 6)
  5. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 5, imagem 1 %32
    • Once the cover is off, this is what your device will look like.
  6. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: passo 6, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Battery: passo 6, imagem 2 %32
    • Once you have the case off of your device gently pull your battery away from the device.
    • Do not attempt to completely remove the battery, as it is still attached to the motherboard by wires.
  7. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 7, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 7, imagem 2 %32
    • With a pair of Tweezers remove the yellow tape covering the battery wires.
  8. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 8, imagem 1 %32
    • After removing the tape you may use the Tweezers to remove the wiring harness from the circuit board.
    • Do not squeeze the wires to hard you may damage them and cause a short.
  9. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 9, imagem 1 %32
    • You may now replace the battery in your Verizon Ellipsis Jetpack MHS800L.
  10. Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, imagem 2 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement, Screen: passo 10, imagem 3 %32
    • Locate the LCD screen cable and unlatch the harness connection form the circuit board.
  11. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 11, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 11, imagem 2 %32
    • Using the Tweezers gently coax the display data cable out of circuit board connector.
    • Do not squeeze the display data cable to hard you may damage it and cause a short.
  12. Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 12, imagem 1 %32 Verizon Ellipsis Jetpack MHS800L Screen Replacement: passo 12, imagem 2 %32
    • Gently insert the Tweezers underneath the LCD screen and lift the LCD screen off of the circuit board.
Conclusão
Uma outra pessoa concluiu este guia.
Richard J Porras
Membro desde: 01/23/16
504 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 3-3, Baechle Spring 2016 Membro de IUPUI, Team 3-3, Baechle Spring 2016
IUPUI-BAECHLE-S16S3G3
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Ao todo: 2,267
