Introdução
What you can expect from this guide is a step by step process on how to remove the plastic case on a Verizon Ellipsis Jetpack MHS800L.
O que você precisa
Ferramenta utilizada nesse passo:Phillips #00 Screwdriver$5.49
With the device on its back and the label facing you, remove the rubber screw cover on the top left corner of the device.
Under the rubber circle, remove the 1.25 mm screw using a Phillips #00 Screwdriver.
Ferramenta utilizada nesse passo:iFixit Opening Picks (Set of 6)$4.99
Use a plastic pick at the seams and pry open the case.
