Ir para o conteúdo principal
Verizon Ellipsis 8 Button Replacement
O que você precisa
  1. Verizon Ellipsis 8  Button Replacement, Power/Volume Buttons: passo 1, imagem 1 %32
    • First, use a plastic opening tool in order to slowly pry across the crevasse on the side of the device. This plastic back of the device will un-click during this process and you will remove the back piece.
  2. Verizon Ellipsis 8  Button Replacement: passo 2, imagem 1 %32
    • Using your fingers, firmly grasp either the power button or the volume buttons and remove them, releasing the clasps that hold the buttons into place.
  3. Verizon Ellipsis 8  Button Replacement: passo 3, imagem 1 %32
    • Now, using your fingers replace the buttons that you have removed in the previous step with the new functioning buttons. Enter the button in at an angle and press it into place, clicking it into the open slot. To reassemble your device, follow these instructions in reverse order.
Conclusão
Jack
Membro desde: 02/06/19
589 Reputação
Autoria de 3 guias
Equipe
UC Davis, Team S18-G6, Lore Winter 2019 Membro de UC Davis, Team S18-G6, Lore Winter 2019
UCD-LORE-W19S18G6
Membros da 3
Autoria de 3 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 465
