Introdução
This guide is designed to provide you with a visual and technical description to remove the battery of the Verizon Ellipsis 10.
O que você precisa
Remove the bottom piece of tape securing the battery making sure you are not peeling up anything else in the process.
To reassemble your device, follow these instructions in reverse order using new tape to secure the battery.
3 outras pessoas executaram este guia.
