Ir para o conteúdo principal
Velocity NoteMagix M10 A82 Hard Drive Replacement
O que você precisa
  1. Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Velocity NoteMagix M10 A82 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 2, imagem 1 %32 Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 2, imagem 2 %32
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Velocity NoteMagix M10 A82 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Unscrew the two 3.65mm Phillips #1 screws on the plate marked "HDD".
  4. Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 4, imagem 1 %32
    • Lift the HDD plate off of the back to reveal the hard drive.
  5. Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 5, imagem 1 %32 Velocity NoteMagix M10 A82 Hard Drive Replacement: passo 5, imagem 2 %32
    • Use the spudger to push the area above the connector on the hard drive to the right.
    • Lift the hard drive gently from the computer with the spudger.
Conclusão
Sam Middleton
Membro desde: 10/01/13
401 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-9, Forte Fall 2013 Membro de Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 330
