Ir para o conteúdo principal
Velocity NoteMagix M10 A82 DDR RAM Replacement
O que você precisa
  1. Velocity NoteMagix M10 A82 DDR RAM Replacement, Battery: passo 1, imagem 1 %32 Velocity NoteMagix M10 A82 DDR RAM Replacement, Battery: passo 1, imagem 2 %32
    • Place the notebook on the table, with the battery facing away from you.
    • Slide the switch from "lock" to "unlock" with your right hand on the right side of the computer.
    • Maintain holding the right switch in the "unlock" position.
    • Use your left hand to slide the left switch from "lock" to "unlock".
  2. Velocity NoteMagix M10 A82 DDR RAM Replacement: passo 2, imagem 1 %32 Velocity NoteMagix M10 A82 DDR RAM Replacement: passo 2, imagem 2 %32
    • Maintain both left and right switches in the "unlock" position.
    • Use your forefingers to push the battery out of the computer.
  3. Velocity NoteMagix M10 A82 DDR RAM Replacement, RAM: passo 3, imagem 1 %32 Velocity NoteMagix M10 A82 DDR RAM Replacement, RAM: passo 3, imagem 2 %32
    • Locate the DDR panel and unscrew the two 3.65mm Phillips #1 screws holding it in place.
    • Use the spudger to lift the DDR panel off.
  4. Velocity NoteMagix M10 A82 DDR RAM Replacement: passo 4, imagem 1 %32 Velocity NoteMagix M10 A82 DDR RAM Replacement: passo 4, imagem 2 %32 Velocity NoteMagix M10 A82 DDR RAM Replacement: passo 4, imagem 3 %32
    • Push in the tabs on the sides that contain the RAM.
    • Gently raise the RAM up to a 45 degree angle and gently pull the RAM towards you.
Conclusão
Sam Middleton
Membro desde: 10/01/13
401 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 14-9, Forte Fall 2013 Membro de Cal Poly, Team 14-9, Forte Fall 2013
CPSU-FORTE-F13S14G9
Membros da 5
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 370
