Ir para o conteúdo principal
Velocity Micro Cruz T301 Speakers Replacement
O que você precisa
  1. Velocity Micro Cruz T301 Speakers Replacement, Speakers: passo 1, imagem 1 %32
    • Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
    • Use the opening tool to pry the back plate up.
  2. Velocity Micro Cruz T301 Speakers Replacement: passo 2, imagem 1 %32
    • Insert a second opening tool into the space created by the first opening tool.
  3. Velocity Micro Cruz T301 Speakers Replacement: passo 3, imagem 1 %32
    • Remove the first opening tool.
  4. Velocity Micro Cruz T301 Speakers Replacement: passo 4, imagem 1 %32 Velocity Micro Cruz T301 Speakers Replacement: passo 4, imagem 2 %32
    • Slide the opening tool across the back plate to disconnect the clips joining the plate to the tablet.
  5. Velocity Micro Cruz T301 Speakers Replacement: passo 5, imagem 1 %32
    • Remove the four screws in the metal plate covering the battery using a Phillips #0 screwdriver.
  6. Velocity Micro Cruz T301 Speakers Replacement: passo 6, imagem 1 %32
    • Using a plastic spudger to remove the battery connector.
    • Failure to follow this step may result in an electric shock.
  7. Velocity Micro Cruz T301 Speakers Replacement: passo 7, imagem 1 %32
    • Remove the battery with a spudger.
    • The photos in this guide use a metal spudger. Do not use a metal spudger as it can damage the device or conduct electricity causing a shock.
  8. Velocity Micro Cruz T301 Speakers Replacement: passo 8, imagem 1 %32
    • Remove the twelve screws in the cover with a Phillips #0 screwdriver.
  9. Velocity Micro Cruz T301 Speakers Replacement: passo 9, imagem 1 %32
    • Place a spudger between the tablet base and the screen.
    • Again this photo shows the use of a metal spudger. The use of a metal spudger can cause damage to the device and can lead to an electric shock.
  10. Velocity Micro Cruz T301 Speakers Replacement: passo 10, imagem 1 %32
    • Move the spudger around the face to release the clips attached to the tablet base.
  11. Velocity Micro Cruz T301 Speakers Replacement: passo 11, imagem 1 %32
    • Locate the speaker on the motherboard. Use the plastic spudger to disconnect the speaker from the connection port.
    • Plug the new speaker into the port, then use the plastic spudger to gently push it in.
Conclusão
Equipe
USF Tampa, Team 1-6, Cagle Fall 2016 Membro de USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 124
