Introdução
The Velocity Micro Cruz T301 is a tablet that is specifically designed as a multimedia device. The speaker is necessary for all audio based media. As such, it can be a vital part of the user’s experience.
This guide will show you the steps to remove the speaker on a tablet. Once the speaker is removed follow the guide in reverse to install a new speaker.
O que você precisa
Insert an opening tool in the SD port, with the edge pointing towards the rear panel.
Use the opening tool to pry the back plate up.
