Ir para o conteúdo principal
Velocity Micro Cruz T301 Battery Replacement
O que você precisa
  1. Velocity Micro Cruz T301 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Insert the plastic iFixit opening tool into the SD port. Orient the iFixit opening tool so that the edge faces the rear panel.
  2. Velocity Micro Cruz T301 Battery Replacement: passo 2, imagem 1 %32
    • Use the iFixit opening tools to pry open a gap between the tablet and rear panel.
  3. Velocity Micro Cruz T301 Battery Replacement: passo 3, imagem 1 %32 Velocity Micro Cruz T301 Battery Replacement: passo 3, imagem 2 %32
    • Move the small tool opener around the rear panel to free the 12 clips.
  4. Velocity Micro Cruz T301 Battery Replacement: passo 4, imagem 1 %32
    • Remove the four screws in the metal battery housing using the Phillips #0 screwdriver.
  5. Velocity Micro Cruz T301 Battery Replacement: passo 5, imagem 1 %32
    • Disconnect the battery using the spudger.
  6. Velocity Micro Cruz T301 Battery Replacement: passo 6, imagem 1 %32
    • Lift the battery out of its place with a nylon spudger.
    • This photo shows the use of an incorrect tool. Always use an ESD safe tool, like the nylon spudger, when dealing with delicate components.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
USF Tampa, Team 1-6, Cagle Fall 2016 Membro de USF Tampa, Team 1-6, Cagle Fall 2016
USFT-CAGLE-F16S1G6
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 526
