Introdução
This guide is for replacing a dying or faulty battery in your Micro Cruz Tablet. This replacement is not overly difficult and can be completed in less than an hour. You will need to be careful when opening the device up because the stress can cause some damages.
O que você precisa
Insert a plastic opening device into the small crack separating the screen and the back of the device.
After the back of the device is separated, remove the back and you can now access the battery.
Uma outra pessoa concluiu este guia.
