Introdução
This guide will go over how to change the key switches on your Varmilo MA87M Love Birds mechanical keyboard. The possible hazard of this procedure is breaking the key switches. The switches and keyboard are sensitive so proceed with caution.
O que você precisa
Remove the keycaps from the keyboard using the keycap removal tool.
Make sure the keyboard is disconnected from the computer or the computer is turned off during this process.
Now, remove the switches from the keyboard. You will remove the switch by aligning the keyboard remover along the groves at the bottom of the switch to remove them. Then gently pull up towards you so the switch will come out of its slot.(Be Careful if you damage a switch, you will need a new switch to replace it)
