Ir para o conteúdo principal
Varmilo MA87M Love Birds Switch Replacement
O que você precisa
  1. Varmilo MA87M Love Birds Switch Replacement, Switch: passo 1, imagem 1 %32 Varmilo MA87M Love Birds Switch Replacement, Switch: passo 1, imagem 2 %32 Varmilo MA87M Love Birds Switch Replacement, Switch: passo 1, imagem 3 %32
    • Remove the keycaps from the keyboard using the keycap removal tool.
    • When the keycaps are removed they can be cleaned at this time.
    • Make sure the keyboard is disconnected from the computer or the computer is turned off during this process.
  2. Varmilo MA87M Love Birds Switch Replacement: passo 2, imagem 1 %32 Varmilo MA87M Love Birds Switch Replacement: passo 2, imagem 2 %32
    • Now, remove the switches from the keyboard. You will remove the switch by aligning the keyboard remover along the groves at the bottom of the switch to remove them. Then gently pull up towards you so the switch will come out of its slot.(Be Careful if you damage a switch, you will need a new switch to replace it)
    • Be Careful if you damage a switch, you will need a new switch to replace it
  3. Varmilo MA87M Love Birds Switch Replacement: passo 3, imagem 1 %32
    • Insert the new switch into the slot where the old one was removed from and push down on the switch.
  4. Varmilo MA87M Love Birds Switch Replacement: passo 4, imagem 1 %32 Varmilo MA87M Love Birds Switch Replacement: passo 4, imagem 2 %32
    • When the new switch is inserted the keycap can be slotted on and pushed easily back into place
Conclusão
Josue Vargas Sena
Membro desde: 10/25/23
181 Reputação
Autoria de 2 guias
Equipe
Team Jansport Membro de Team Jansport
Community
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Duração total: 177
