Ir para o conteúdo principal
Vanmoof No 3 Replacement Mudguards
  1. Vanmoof No 3  Replacement Mudguards, Get the Mudguards: passo 1, imagem 1 %32
    • Make sure you get 2 mudguards, one set of stays that are straight for the rear, and a second that have a bend. Also make sure you have the two rear connection pieces.
  2. Vanmoof No 3  Replacement Mudguards, The problem: passo 2, imagem 1 %32
    • You need to cut both sides of the mudguard so it can fit between the chain stays, and drill a new hole to attach to the bottom of the frame.
  3. Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: passo 3, imagem 1 %32 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: passo 3, imagem 2 %32 Vanmoof No 3  Replacement Mudguards, Cut the rear mudguard: passo 3, imagem 3 %32
    • The rear mudguard will need to be cut at the front.
    • First cut at parallel to the bottom about 16mm long
    • Second cut is 7mm in from the rounded edge
  4. Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: passo 4, imagem 1 %32 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: passo 4, imagem 2 %32 Vanmoof No 3  Replacement Mudguards, Bend over the metal to make the edge: passo 4, imagem 3 %32
    • Bend the edges over so you make a rounded lip
  5. Vanmoof No 3  Replacement Mudguards, Drill the new hole: passo 5, imagem 1 %32
    • Drill the frame attachment hole
    • Bolt to the frame
Conclusão
Martin Hampton
Membro desde: 02/13/16
1.329 Reputação
Autoria de 7 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 1,125
