Introdução
An instructional video for installing a pop-top tent on a Vanagon (1985-1991). This video gives you everything you need to know in order to install the screw-in style tent.
Not to be confused with the staple in type found on the earlier 1980-1985 Westfalia. If you are unsure of which style you have, the screw-in style will have metal rails attaching the tent at the top.
This repair is best done with a friend or two as it is recommended that the fiberglass top is removed from the vehicle.
O que você precisa
Instruções em vídeo
Make sure to keep the new tent clean and dry as this will allow it to last for years.
0 comentários
