Introdução
If you are experiencing no crank on key turn, it is likely either a dead battery or worn out ignition switch. If the battery is charged, please disconnect, and try replacing the ignition switch with a new one.
This video will show you how to remove the steering wheel in order to gain access to the ignition switch housing.
O que você precisa
Instruções em vídeo
Quase terminado!
Conclusão
0 comentários
