Ir para o conteúdo principal
VTechCS6719-16 Button Replacement
O que você precisa
  1. VTechCS6719-16 Button Replacement, Buttons: passo 1, imagem 1 %32
    • Remove the sliding back cover from case.
  2. VTechCS6719-16 Button Replacement: passo 2, imagem 1 %32
    • lift the battery and unplug the two pin cable from phone base.
  3. VTechCS6719-16 Button Replacement: passo 3, imagem 1 %32
    • Remove the two 10mm screws at the base of the phone .
  4. VTechCS6719-16 Button Replacement: passo 4, imagem 1 %32
    • Use the spudger along the edge using a firm but gentle lifting motion.
    • When doing this feel for the hooks that latch the phones front and back cases.
  5. VTechCS6719-16 Button Replacement: passo 5, imagem 1 %32
    • Unscrew a second set of 10mm screws to obtain access to the other side.
  6. VTechCS6719-16 Button Replacement: passo 6, imagem 1 %32
    • The front of the phone can now be placed to the side
    • You will notice the button covers, these display the numerical values and positions of each button
    • These can be placed aside as they will get in the way later.
  7. VTechCS6719-16 Button Replacement: passo 7, imagem 1 %32
    • Now the silicon pads for the phone buttons are exposed.
    • These can easily be removed by pulling away the pads from the circuit board.
    • To replace simply align the new pad onto the button positions.
Conclusão
Charles montes
Membro desde: 10/20/16
513 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 5-5, Martin Fall 2016 Membro de UMass Dartmouth, Team 5-5, Martin Fall 2016
UMASSD-MARTIN-F16S5G5
3 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 299
