Ir para o conteúdo principal
VTech Touch and Swipe Baby Phone Battery Replacement
O que você precisa
  1. VTech Touch and Swipe Baby Phone Battery Replacement, Battery: passo 1, imagem 1 %32 VTech Touch and Swipe Baby Phone Battery Replacement, Battery: passo 1, imagem 2 %32
    • Using a Phillips #1 screwdriver, remove the 4.8mm screw on the battery cover by twisting the screwdriver counter-clockwise.
  2. VTech Touch and Swipe Baby Phone Battery Replacement: passo 2, imagem 1 %32 VTech Touch and Swipe Baby Phone Battery Replacement: passo 2, imagem 2 %32 VTech Touch and Swipe Baby Phone Battery Replacement: passo 2, imagem 3 %32
    • Remove the two AAA batteries by pulling on one end of the battery and lifting it straight out.
  3. VTech Touch and Swipe Baby Phone Battery Replacement: passo 3, imagem 1 %32 VTech Touch and Swipe Baby Phone Battery Replacement: passo 3, imagem 2 %32 VTech Touch and Swipe Baby Phone Battery Replacement: passo 3, imagem 3 %32
    • When reassembling, align the notch on the battery panel with the slot on the phone.
Conclusão
Uma outra pessoa concluiu este guia.
Zack Drawdy
Membro desde: 09/04/15
231 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-4, Sullivan Fall 2015 Membro de USF Tampa, Team 2-4, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G4
Membros da 3
Autoria de 12 guias
2 comentários
Seems this device is VERY sensitive to low batteries. An issue I assumed was the power switch (randomly turning off) was actually batteries. Also hilarious this has an iFixit page.
Chris Uthe - Responder
Thank you! Changing the batteries fixed the loop issue
Jessica Dorado - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 1,075
