Ir para o conteúdo principal
VTech Spin and Learn Color Flashlight Ladybug Button Replacement
O que você precisa
  1. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Battery Housing: passo 1, imagem 1 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Battery Housing: passo 1, imagem 2 %32
    • Locate the battery housing on the back of the flashlight as pictured.
    • Unscrew the single 8 mm Phillips #1 screw.
    • The screw will stay attached to the cover that will be removed.
    • Lift the battery housing cover to reveal the battery terminals. Remove the batteries.
  2. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Speaker Housing: passo 2, imagem 1 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Speaker Housing: passo 2, imagem 2 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Speaker Housing: passo 2, imagem 3 %32
    • Locate the light blue speaker housing on the bottom of the flashlight.
    • Remove the three 6 mm Phillips #0 screws.
    • Once the screws have been removed, pull the housing away from the yellow body of the flashlight. Be careful not to disconnect the white wires from the speaker, unless speaker replacement is required.
  3. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Red Ring: passo 3, imagem 1 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Red Ring: passo 3, imagem 2 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Red Ring: passo 3, imagem 3 %32
    • Locate the screw covering stickers on the side of the red ring. These two stickers will be slightly larger than the normal stickers. In this case it was a ladybug and a duck on opposite sides of the ring.
    • With a plastic opening tool, gently remove the stickers by prying around the edges. Be careful with these as you will want to reapply them later
  4. VTech Spin and Learn Color Flashlight Ladybug Button Replacement: passo 4, imagem 1 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement: passo 4, imagem 2 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement: passo 4, imagem 3 %32
    • Remove the two 8mm Phillips #0 screws from the screw channels found under the stickers in step one. This can be seen in the first photo if step 2.
    • Once the screws have been successfully removed, grasp one half of the ring and pull gently to separate it from the yellow housing. Repeat on the opposite side and the ring is disassembled.
  5. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Main Housing: passo 5, imagem 1 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Main Housing: passo 5, imagem 2 %32
    • Unscrew the six 8 mm Phillips #0 screws at each of the points circled in red in the first image.
    • To open, separate the two sides of the housing. They should come apart fairly easily, however you may use a spudger to pry it open. Once it's apart, it should look like the second image.
  6. VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Ladybug Button: passo 6, imagem 1 %32 VTech Spin and Learn Color Flashlight Ladybug Button Replacement, Ladybug Button: passo 6, imagem 2 %32
    • Locate the ladybug button on the handle of the opened flashlight and remove it from its slot.
Conclusão
Mahmoud Khalifa
Membro desde: 08/26/15
253 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 2-6, Blackwell Fall 2015 Membro de USF Tampa, Team 2-6, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G6
3 Membros
Autoria de 18 guias
1Comentário do guia
I did same thing with one of my tactical flashlight https://tacticalflashlightguide.com/ and it’s worked as well. I have changed my flashlight button without any problem.
kineeok - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Ao todo: 376
