Ir para o conteúdo principal
VTech Safe And Sound DM221 Speaker Replacement
O que você precisa
  1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: passo 1, imagem 1 %32
    • Remove the battery cover.
  2. VTech Safe And Sound DM221 Speaker Replacement: passo 2, imagem 1 %32
    • Unplug the battery from its connector and remove.
  3. VTech Safe And Sound DM221 Speaker Replacement: passo 3, imagem 1 %32
    • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
  4. VTech Safe And Sound DM221 Speaker Replacement: passo 4, imagem 1 %32
    • Separate the back half of the device from the front using the metal spudger.
  5. VTech Safe And Sound DM221 Speaker Replacement: passo 5, imagem 1 %32
    • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
    • This will allow the removal of the silver handle.
  6. VTech Safe And Sound DM221 Speaker Replacement: passo 6, imagem 1 %32
    • Remove the “TALK” button to get access to remove the motherboard.
  7. VTech Safe And Sound DM221 Speaker Replacement: passo 7, imagem 1 %32
    • Push down on the antenna, located on the top of the motherboard.
  8. VTech Safe And Sound DM221 Speaker Replacement: passo 8, imagem 1 %32
    • Gently remove the motherboard away from the monitor.
    • Be careful not to disconnect the red wire.
  9. VTech Safe And Sound DM221 Speaker Replacement: passo 9, imagem 1 %32
    • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
Conclusão
Krystal
Membro desde: 10/01/15
600 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-5, Leahy Fall 2015 Membro de USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 342
