Ir para o conteúdo principal
VTech Safe And Sound DM221 Buttons Replacement
O que você precisa
  1. VTech Safe And Sound DM221 Buttons Replacement, Buttons: passo 1, imagem 1 %32
    • Remove the battery cover by sliding it down.
  2. VTech Safe And Sound DM221 Buttons Replacement: passo 2, imagem 1 %32
    • Firmly grasp the battery and pull to disconnect the battery from its connector.
  3. VTech Safe And Sound DM221 Buttons Replacement: passo 3, imagem 1 %32
    • Using a Phillips #00 screwdriver, unscrew the two 5.0 mm screws located at the bottom of the monitor inside of the device.
  4. VTech Safe And Sound DM221 Buttons Replacement: passo 4, imagem 1 %32
    • Using a plastic opening tool, pry apart the front part of the device from the back. There are many access points, but the best spot to insert the spudger is around the "TALK" button.
    • Avoid using the metal spudger. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
  5. VTech Safe And Sound DM221 Buttons Replacement: passo 5, imagem 1 %32 VTech Safe And Sound DM221 Buttons Replacement: passo 5, imagem 2 %32
    • Remove the buttons from the front part of the device.
    • Tip: The buttons on the front of the device (“POWER,” “SELECT,” “MENU,” “VOLUME”) are all connected as one unit. Pull them out carefully.
Conclusão
Krystal
Membro desde: 10/01/15
600 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 1-5, Leahy Fall 2015 Membro de USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Duração total: 366
