Introdução
Is your antenna not picking up the monitor signal? Read this repair guide to find out how to replace your antenna.
O que você precisa
Remove the battery cover by sliding it down.
Firmly grasp the battery and pull to disconnect the battery from its connector.
Using a Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws located at the bottom of the monitor inside of the device.
Conclusão
1Comentário do guia
Great tutorial thanks! What type of antenna should I replace it with to get better reception?
