Ir para o conteúdo principal
VTech Record and Learn KidiStudio Microphone Replacement
O que você precisa
  1. VTech Record and Learn KidiStudio Microphone Replacement, Microphone: passo 1, imagem 1 %32 VTech Record and Learn KidiStudio Microphone Replacement, Microphone: passo 1, imagem 2 %32
    • Remove all four screws (7 mm) using PH2.
    • Remove black microphone base cover from the device.
    • Remove the batteries from the toy before beginning replacement of the microphone.
  2. VTech Record and Learn KidiStudio Microphone Replacement: passo 2, imagem 1 %32
    • Remove the silver microphone component from the black base.
  3. VTech Record and Learn KidiStudio Microphone Replacement: passo 3, imagem 1 %32 VTech Record and Learn KidiStudio Microphone Replacement: passo 3, imagem 2 %32
    • Unscrew 4 PH2 screws (7 mm) from the silver microphone component.
    • Open the silver microphone housing and remove the actual microphone from the device.
  4. VTech Record and Learn KidiStudio Microphone Replacement: passo 4, imagem 1 %32
    • Install new microphone in the device like shown.
Conclusão
Shaina Carbonel
Membro desde: 02/01/16
537 Reputação
Autoria de 5 guias
Equipe
UW Tacoma, Team 1-1, Rose Winter 2016 Membro de UW Tacoma, Team 1-1, Rose Winter 2016
UWT-ROSE-W16S1G1
5 Membros
Autoria de 10 guias
1Comentário do guia
What type of microphone? Where do u get the replacement
Tika S - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 794
