Ir para o conteúdo principal
Introdução
Prerequisite Only
Peças
Nenhum componente especificado.
  1. Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device. Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
    • Position the VTech Little Apps Tablet face-down on a flat surface so that you can clearly see the back of the device.
    • Remove all seven 9.6 mm screws located around the perimeter of the back cover with a PH1 driver head.
  2. Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down. Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
    • Gently remove the back cover then flip it 180 degrees so that the back cover of the device is now face-down.
    • Proceed with caution as there are wires attaching the back cover to the front cover of the device that could be easily detached.
Conclusão
Johnnie Cairns
Membro desde: 10-02-2016
495 Reputation
4 Guias de autoria
USF Tampa, Team 2-6, Sullivan Spring 2016 Membro de USF Tampa, Team 2-6, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G6
3 Membros
6 Guias de autoria
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 67
