Ir para o conteúdo principal
VTech Learning Tunes Karaoke Power Button Replacement
O que você precisa
  1. VTech Learning Tunes Karaoke Power Button Replacement, Power Button: passo 1, imagem 1 %32
    • To remove the battery door, loosen the 4mm screw using a Flathead screwdriver.
    • A coin can also be used to loosen the screw
    Pergunte ao FixBot
    Comentar
  2. VTech Learning Tunes Karaoke Power Button Replacement: passo 2, imagem 1 %32 VTech Learning Tunes Karaoke Power Button Replacement: passo 2, imagem 2 %32
    • Remove the battery door and take out the batteries.
    Pergunte ao FixBot
    Comentar
  3. VTech Learning Tunes Karaoke Power Button Replacement: passo 3, imagem 1 %32
    • Remove the six 9.5 mm Phillips #2 screws.
    • Remove the six 6.0 mm Phillips #2 screws.
    Pergunte ao FixBot
    Comentar
  4. VTech Learning Tunes Karaoke Power Button Replacement: passo 4, imagem 1 %32 VTech Learning Tunes Karaoke Power Button Replacement: passo 4, imagem 2 %32
    • Gently pull up on the rear panel.
    • Be careful to not pull on the wire connections.
    • Gently place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
    Pergunte ao FixBot
    Comentar
  5. VTech Learning Tunes Karaoke Power Button Replacement: passo 5, imagem 1 %32
    • Remove four 7.9 mm screws from the mode selector and voice selector trays.
    Pergunte ao FixBot
    Comentar
  6. VTech Learning Tunes Karaoke Power Button Replacement: passo 6, imagem 1 %32
    • Remove the two 5.6 mm screws from the power button board.
    Pergunte ao FixBot
    Comentar
  7. VTech Learning Tunes Karaoke Power Button Replacement: passo 7, imagem 1 %32
    • Carefully move the power button board out of the way.
    • From here you can replace the button.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
USF Tampa, Team 7-2, Cheng Spring 2016 Membro de USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Membros
Autoria de 10 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 675
